canon NP6050 error code E210
  • mikem
    Moved machine across the office maybe 15 feet now I get error code 210 and it tells me to turn power off and back on. From what i have found out the len is not in home position. If this is correct can someone tell me what to do, If not correct can someone tell me what my problem is.
    thank you
    mike mullen
    • 22997
    Just watch the lens home out.
    The tape on the lens cover may have peeled off and is obstructing the lens. Re-stick tape out of the lens path, or replace the lens cover (FF5-3077-050).
    What you need to do is turn off the power, remove the glass, and lens cover. Reinstall the glass, & power up. As the machine is initializing you'll see the lens assembly move to home position then back to 100%.
    Or, you'll see why it doesn't. Pay attention to any attempts of the lens to move.
