System Buck Up
  • gensys
    • Jan 2011
    • 324
    [CQ] System Buck Up
    How to make full Buck Up of system on iR 5570?
    Thanks!!!!!!
    The Road will be Mastered by >>> the Going...
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5005
    Thanks!!!!!!
    Use SST
    use safe mode for uploading
    1.select upload data
    2.Select the data you want to back up
    3.Click [Start].
    4.Enter a name of the file to be saved, and fill out a memo as needed. Then, click the save button
    5.Click [OK].
    • gensys
      • Jan 2011
      • 324
      Thanks dear friend
      Tell please where I can find SST, it seems on the Internet is not present
      With best regards. General System Co. Ltd.
      gensysarm@hotmail.com
      gensysarm@mail.ru
      • zoraldinho
        • Mar 2008
        • 5005
        Sorry but you need to be a certified Canon service to have SST.If you still won't to have SST
        i must to worn you that is not a toy.One wrong click and your system is down for good.
        • gensys
          • Jan 2011
          • 324
          • gensys
            • Jan 2011
            • 324
            Whether I want to have 2 GB SDRAM, probably it
            Thanks!!!!!
            • zoraldinho
              • Mar 2008
              • 5005
              I have 2 DDR SDRAM 128Mb sumary 512Mb on my mashin,
              Whether I can deliver 2DDR SDRAM on 1gb or >>>
              Thanks!!!!!
              I don't really understand your question but maybe this help.
              • gensys
                • Jan 2011
                • 324
                I have image of the HDD Full(MBR + Partition) with Acronis True Image Echo Enterprise Server it has turned out an order 3.6 Gb,
                But system full Buck Up it is impossible while.......
                • gensys
                  • Jan 2011
                  • 324
                  I will try will put SDRAM 1Gb I will look that will turn out and that, I send on iR an order 20-30 Mb iR very long thinks, at me there is HP1200 LaserJet it on much more bright
                  • gensys
                    • Jan 2011
                    • 324
                    Version SST 4.11 on the Internet seems to eat
