Canon ir7105, imagepass S2 mac driver problems
  • tack
    • Jan 2011
    • 43
    we are running mac leopard 10.5.8
    when we install the driver for the imagepass S2 2.0 (which only goes to 10.4 os) the driver installs.
    when we go to print the driver crashes (Poof disapears from screen).
    there must be a updated driver to handle the 10.5.8 os.
    does anyone have this problem and a work around or advice?
    many thanks
  • teckat
    • 16083
    many thanks
    imageRUNNER 7105
    imageRUNNER 7086 / 7095 / 7095P / 7105
    Mac Drivers
    Canon U.S.A. : Support & Drivers : imageRUNNER 7105
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Originally posted by teckat
      imageRUNNER 7105
      Mac Drivers
      Teckat, this link only points to the internal controller drivers, not the Fiery ones.
      Unfortunately, Canon never did release an M2 driver for the newer Mac OSes.
      One work around: Download and install the Windows PostScript driver for the M2 on a PC, and print a test page.
      Copy the .ppd file that shows on the test page to your Mac, and point to that file when installing the driver.
      In theory, .ppd files are not platform specific, so this trick should work
      • teckat
        • 16083
        U mean for imagePass S2
        • D_L_P
          Self Employed
          • Oct 2009
          • 1196
          Here are the drivers the ImagePass-S2:
          Canon U.S.A. : Support & Drivers : imagePASS-S2
          Strange but it looks like the S2 v1.0 supports 10.5.x, while S2 v2.0 doesn't. I'd downgrade the imagepass to v1.0, uninstall the S2 v2.0 and then install the S2 v1.0 ppd that supports 10.5.x.
          Thanks KenB, I forgot about your trick. Good call.
          • teckat
            • 16083
            How to print jobs from Macintosh OSX v10.6 (Snow Leopard)
            imagePASS S1/S2/C2/G1/J1
            Technical Publication is to explain how to print jobs from Mac OS X v10.6 (Snow Leopard) to the imagePASS S1/S2/C2/G1 and J1 Fiery controllers using the Mac OSX v10.5 Postscript drivers for these controllers.
            TP10-1.pdf
            • anothertech
              • 1771
              That's what I saw too, could it be a misprint? It doesn't seem right that they would go backwards like that.
              • teckat
                • 16083
                many thanks
                TP10-1.pdf
                The following affected devices currently do not have Mac OSX v10.6 (Snow Leopard) PS driver. Canon has released the Print Driver Updater tool to enable printing from Snow Leopard to these controllers using the Mac OSX v10.5 Postscript print driver.
                Affected Devices:This updater tool supportsupdater tool
                FieryPrintDriverUpdateforOSXv106.zip
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  My bad on the S2 vs M2; same basic issue, though.
                  For whatever it may be worth, I have a customer with an S2 (iR7105) who just upgraded to Windows 7, 64 bit.
                  No PS drivers available, but there are PCL drivers.
                  What's up with that??
                  • tack
                    • Jan 2011
                    • 43
                    thank you KenB
                    so far this is working fine!
                    also fixed a same issue printing to a c500 from the mac.
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      thank you KenB
                      Glad it's working for you!
