IR-5055 DADF White plate part #
  • ReproKev
    • 273
    I have the parts manual and found the white plate in Fig A10 of the 5055 parts manual (rev 0) but there is no part number listed (it's the white plate that attaches to the bottom of the DADF and sits on the platin glass) for it and the double sided sponges that attach it.
    Anyone have the numbers?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    If you have DADF-m1 is dis what are you looking for.
    FL2-0728-000 PANEL, COPYBOARD
    • ReproKev
      • 273
      Yes and no. Yes - that is basicly the part. No - It's the wrong DADF. The DADF-M1 is on the 5570/6570. I need the DADF (couldn't find a specific model number) on the 5055. The white plate is flexible and bends down if the customer lowers the bottom left side to remove a jam. The one from the diagram above is what I need.
      The parts manual for it is located in the 5055 main body parts manual on figure A10 but no diagram number is listed.
      Thanks for the effort though. Anyone else have a number.
      • charm5496
        • 2387
        FL2-4596-000 is the number for the white plate.
        • ReproKev
          • 273
          Thanks. Do you know if it comes with the mounting sponges?
          • charm5496
            • 2387
            no it does not. you will need 4 each of.
            FC7-9879-000
            FC7-3163-000
            There is another set of foam sponges (qty 4) but no part number assigned to them that I can find at the moment
            • ReproKev
              • 273
              Thanks again.
              • charm5496
                • 2387
                not a problem Kev. Good luck!!!
