i have a ir3045 which had screen not booting up, the main controller was changed and sorted screen out, but now the copy and express copy tabs have disapeared sysyem software updated!! any thoughts please
Never seen a missing COPY TAB if u have this setting-Check in Service Mode that UI-Copy is set to 1.
( Copier>Option>Body> UI-Copy )
U just can't pop a Main Controller in.
there are steps u need to follow before & after U may need to do a Clear>MN-CON>then press OK but P PRINT settings need to be re input/also address book settings need to be put back in
Do u have a P Print with settings ? Service Label [2] for the Main Controller PCB/DC controller PCB(behind the front cover unit of the printer unit)
Press the [Additional Functions] button, then select [Copy Settings] > [Standard Key Settings for Express Copy Screen]
(Additional Functions) [Common Settings].
Press [Initial Function].
(Additional Functions)[Common Settings] [Settings for Function Order].
Have you done the MN-CON clear? or tried an MMI clear?
I'm with teckat and have never seen the copy option tab removed. I take it that you didn't see anything on the p-print missing against what you service currently has now?
main controller from canon,....on canon partnernet shows fault of not showing copy and copy express tabs but the fault they talk about also cant get into service mode or additional functions, but on this machine i can !!
you are having more issues with this one that just dont make any sense at all.
I would double check all the connectors that are going to the main controller and make sure they are seated correctly and you aren't missing one. Specifically the ribbon cable that goes from the Reader controller to the main controller.
COPIER > DISPLAY > ACC-STS
FEEDER DADF connection status
0: Not connected 1: Connected
MN CON should not have cleared RCON settings ~!!!!!!!!!!!!!!!!!
Check service label (behind reader unit left cover) for original values
COPIER>ADJUST>ADJ-XY>ADJ-X
COPIER>ADJUST>ADJ-XY>ADJ-Y
COPIER>ADJUST>ADJ-XY>ADJ-S
COPIER>ADJUST>CCD>MTF-MG
COPIER>ADJSUT>ADJ-XY>ADJ-Y-DF
FEEDER>ADJSUT>DOCST
FEEDER>ADUST>LA-SPEED
FEEDER>FUNCTION>TRY-A4
FEEDER>FUNCTION>TRY-A5R
FEEDER>FUNCTION>TRY-LTR
FEEDER>FUNCTION>TRY-LTRR
COPIER>FUNCTION>INSTALL>STRDPOS
COPIER>FUNCTION>CCD>DF-WLVL1
COPIER>FUNCTION>CCD>DF-WLVL2
