Ir 7105
  • shazza
    • Nov 2009
    • 96
    [CQ] Ir 7105
    Hi All,
    Went to an ir7105 that has had ongoing Cq grey background but Image is spot on.
    Laser/Corona assy/ Dev unit has been replaced.
    Its Done 5 Million . I suspect Drum has had it!
    Any other ideas?
    Regards
    Shazza
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Originally posted by shazza
    Hi All,
    Any other ideas?
    Regards
    Shazza
    Do you try to polish the drum with powder.Also check dust proof glass.
    • watson
      • Sep 2009
      • 64
      Did you try turning pot. cont. off
      • shazza
        • Nov 2009
        • 96
        Hi,
        Yep no difference going back to change Drum later on week. Will update.
        • charm5496
          • 2387
          is the customer using canon toner?
          pre exposure lamps could be causing an issue as well. check for loose connections.
          • Canuck
            Tech Specialist
            • 1713
            Is blanking clean around perimeter of copy?(does it have background also?)
            • teckat
              • 16083
              Hi,
              One Word= TONER
              • mrfixit51
                Lead Service Technician
                • Oct 2008
                • 1975
                I agree with polishing the drum as part of the normal maintenance of the copier, but dust proof glass is not the issue here, since "light writes" on this model, any crud on the dust proof glass will cause either intrack voids or light copy...
                • MrB
                  • Nov 2009
                  • 147
                  Have you tried the new drum yet
                  5m is alittle high
                  I did have one a few mths ago with the same issue
                  I changed the HVT PCB (After changing everything else - Wires, Deve, Drum, A.P. Kit)
                  The customer was using gen canon toner, so know that wasn't the issue
                  Good Luck
                  • charm5496
                    • 2387
                    We just had one at a corporate print shop go 15.8 million before the surface wouldn't clean off properly anymore. The difference between the 7105 and the 105 amaze me!!! The two other machines in the same room both have over 14 million on their drums as well and CQ is still holding great.
