Canon D780 Getting to the fuser unit.
  • anthony123
    • 62
    [Misc] Canon D780 Getting to the fuser unit.
    Can someone give me directions (or point me where) To remove the fuser unit? I looks like the scanner has to be removed... Is that correct? Have hammer at ready. thanks Anthony
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5012
    Yes,you need to remove scanner.First you need to remove control panel.
    2.Remove reader unit
    3.Remove fixing unit.
    • anthony123
      • 62
      Thanks zoraldinho, That is such a clever design they came up with, WTF. Anyway I finished the machine tonight and it is working minus a few plastic snap tabs. Thanks again for your help.
      • Brian8506
        • 1664
        Next time take off the covers on the left, get a ratchet right angle screw driver and remove from the left side without taking the scanner or any cables off. 3 screws and 3 connectors. I get that out in 5 minutes.
        • zoraldinho
          • Mar 2008
          • 5012
          This is not a canon procedure.It's your way.Sometimes can be better den canons,sometimes
          you can have a lot of broken plastic covers.
          • zoraldinho
            • Mar 2008
            • 5012
            • Brian8506
              • 1664
              4 screws remove cover over power supply and cover over parallel port. Loosen screw for upper cover and it drops down. Disconnect 3 fuser connectors. Remove 3 screws holding fuser in and slide fuser out. Its a whole lot safer than removing scanner with the flat cable which can take what, an hour?
