Canon GP225 error E000
  • unionjack
    • Aug 2025
    [Error Code] Canon GP225 error E000
    The error code E000 suggests a low temp but where will i find the thermister and how do i access it. I would really appreciate some guideance
  • teckat
    • 16083
    Best bet> call for a Canon Trained Tech
    *4* FUNCTION (function mode)
    *4* FUNCTION 01– >
    ERROR (OK : CLEAR)
    To clear an error indication, press ‘ERROR’ on the screen to highlight; then, press the OK key, and turn OFF/ON the main power switch.
    Removing the Fixing Unit
    1) Open the delivery door.
    2) Remove the screw, and remove the fixing assembly inside cover /UPPER LEFT SIDE
    3) Disconnect the four connectors,remove the screw,and remove the grounding screw then,slide out the fixing unit.
    • unionjack
      Thanks Teckat, I will try it first thing Monday. You don't realize how much you'll miss them untill they stop working. Thanks again.
