C1 imagepress color displacement
  • mark921
    • Dec 2010
    • 110
    Just replaced the ITB on C1, along with the 2 trans roller, and now the yellow is off register, moving to the trail edge of the print. Just for for grins, i installed another ITB, but same issue. Hopefully, someone can guide me to a possible fix.
    Cheers
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5005
    Cheers
    Hi dude
    Inspected by Canon Inc. ]
    Description
    Since the ITB connecting shaft was not tightened after the process unit to which a weight and the developing assembly were mounted was set into the main
    body upon installation, yellow was displaced in both copying and printing. The degree of displacement worsen toward the trail edge.
    Field Remedy
    When the symptom occurs at test printing after re-mounting the process unit during installation or servicing, check to see if the ITB connecting shaft is
    loosened; if so, tighten it again and then perform a copy/print job.
    Note: When tightening the ITB connecting shaft [1], hold the drum fixing member [2] to prevent the idle rotation of the shaft.
    • mark921
      • Dec 2010
      • 110
      Thanks!! Worked perfectly. MUCH appreciated!!!
      • zoraldinho
        • Mar 2008
        • 5005
