canon ir 1018 download standby
  • lynx_13
    Re: canon ir 1018 download standby
    good day!
    i have read your query. i am also experiencing the same problem with my copier Canon iR1022.
    have you found a solution to that problem? can you help me how to fix my copier?
    thanks.
    lynx
      • 16083
      you can not put your personal selling links in your post/ read the rules/
      please remove them
      you have been tagged
      Last edited by Aneurysm; 10-20-2012, 06:20 PM. Reason: Edited links in quoted text
      • victor_v
        • 71
        Hi, All
        It seems that there are a lot of similar problems with this ruler...
        At me such:
        I turn on the device - on the display a dark blue background, on it the line of loading is hardly visible; it reaches the end and all...
        buttons of the control panel don't react, it is impossible to enter into a mode of loading (thus at inclusion rotations of knots) are audible;
        wanted to enter vrezhy loadings through "2 & TURN ON" - didn't help;
        if to short-cut JP141, the device NOT TURNS ON ABSOLUTELY!!!
        MNCON died?
        Hardworking people are not present. Simply many it is boring to idle.
        • amg76
          #19
          Exactly my problem. Unfortunately the links were removed I can't find the firmware v60.03 for IRC 1022A anywhere
          • Xliado
            #20
            Dear M friend
            I have same Problem but with IR1024iF, I mean the "Download Standby"..
            Could youi please explain me how to upgrade firmware
            • bipc
              • Sep 2009
              • 194
              #21
              please read teckat's reply, it is very explicit, as for firmware it is not of public access so it wont be just around, only canon certified techs have free access to it.
              teckat quoting
              "teckat
              I believe these models use same compatible Firmware>
              iR1018, iR1022, iR1022A, iR1022F, iR1022i, iR1022iF, iR1023, iR1023iF, iR1023N = Flash ROM 16MB type"
              as for ir1024/A/i/if the firmware is different but by SST also, being this a help forum the firmware will not be for sale here, if you contribute to the forum and ask politelly maybe one of the techs can get it for you
              Life is a learning continuum...
                • 16083
                #22
                Originally posted by Xliado
                Dear M friend
                have no idea about 1024iF firmware/
                do not know what product line in USA that it's compatible with
                instructions for firmware install are posted in this thread link
                http://www.copytechnet.com/forums/ca...d-standby.html
                • tombola
                  #23
                  Originally posted by teckat
                  you do not need to re-load firmware/
                  short pin method could jump u out of that download screen issue
                  report back if issue is not fixed
                  Not working for me, not even after battery change.
                    • 8132
                    #24
                    Just wanted to say thanks for the jpeg, shorting this pin removed the download standby message, after restart machine asked for toner, I fitted a new one & all is good. 😀
                    imageRUNNER 1023iF / 1023N / 1023
                    Machine powers up and Download Mode is displayed
                    Short the two pins at JP141 on the Image Processor Board. This can be done
                    with a screwdriver or an alligator clip.
                    This will reset the machine so system software can be re-flashed.
                    [ATTACH=CONFIG]8400[/ATTACH]
                      • 16083
                      #25
                      ELVIS.jpgwelcome
                      • Elettrozeus84
                        #26
                        Good evening,
                        I have the usual problem of victor_v with canon iR1018.
                        In particular: "I turn on the device - on the display a dark blue background, on it the line of loading is hardly visible; it reaches the end and all...
                        if to short-cut JP141, the device NOT TURNS ON ABSOLUTELY!!!"
                        I have the firmware and the SST program, but I can not connect to the Canon iR1018.
                        No one has the solution?
                        Thank in advance...
                          • 16083
                          #27
                          so this does not work--
                          To put the unit into download mode start with the power off.
                          Press and hold the 2 key only on the ten key pad and then power on the copier.
                          This puts the machine into the download mode. The screen will display Initializing.... for a few moments and then display Download Standby.
                          This method of getting into download mode can be used to recover a failed upgrade or to try to flash a machine that will not boot up and come to ready.
                          if applies to you----Take the PCL PCB out of the machine. -- then see if u can get into download mode, if so, power off, put back PCL and restart printer again.
                          Connection
                          iR1018 / iR1018J / iR1022A / iR1022F / iR1022i / iR1022iF
                          1) Turn off the main power switch of this machine, and then disconnect the cables connected to this machine.
                          2) Connect USB connector ( USB A to B) on the back of this machine to the PC using the USB cable.
                          1. Turn on the power switch of the PC/Laptop and start SST.
                          2. Select "iR1022" in "Model List".
                          3. Double-click the "System" folder in "Model List" to check the system software version. Select "USB" in "Interface", and then click the "START" button.
                          4. Now Turn on the power switch of the host machine.
                          5. Press the following keys on the control panel to enter the service mode.
                          press *Additional Functions Key > [ then #2key then #8key ]> then *Additional Functions Key
                          6. Using the plus (+) or minus (-) key, select "#DOWNLOAD".
                          7. Press the OK key on the control panel to place the host machine in the downloading wait mode ("#DOWNLOAD CONNECTED" is displayed).
                          8. Press the OK button on the SST screen displayed on the display of the PC.
                          install the BootROM first
                          then System
                          then PCL-16M [UFR II LT] or PCL-32M [Network Printer Kit-M1]
                          • Elettrozeus84
                            #28
                            Connection
                            [ATTACH=CONFIG]35275[/ATTACH]
                            then System
                            I tried, but nothing happens, the display is off.
                            This happened:
                            1) At first the canon iR1018 had the error "download standby"
                            2) I performed with succes updating the "system" not the "boot" using SST program.
                            3) Now after the upgrade, when you turn the canon 1018 on, LCD remains off.
                            I also tried to short-circuit JP141, but no effect ...
                            The conditions is this:
                            http://www.copytechnet.com/forums/ca...ghlight=ir1018
                            There may be a solution?
                              • 16083
                              #29
                              This happened:
                              You were supposed to do the Boot first , when doing get 60 or newer.
                              Check and reseat connector J318 on the Image Processor and connector J1701 on the operation panel.
                              Remove ROM pcb and power up, see what happens.
                              • Elettrozeus84
                                #30
                                The connectors are ok.
                                I tried to remove the ROM and starting the copier, but nothing changes...
                                There may be another way to restore the copier, or should I replace the ROM or the CPU card?
                                Thanks in advance.
