open toner door IRA series
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Maybe someone know how can i open toner door on IRA 5045 in service mode?
  • charm5496
    • 2387
    there isn't one in service mode. You have to swing out the main controller cage and use the wrench in the back to open them up. See the attached file for instructions. You can also just pull off the front silver cover that sits just above the hopper doors and you will see little arms on each hopper. Just move them towards the front and the hopper door will open. If you have the internal finisher installed you will have to remove those front covers to gain access to them.
    5051 hopper.pdf
    • zoraldinho
      • Mar 2008
      • 5015
      [ATTACH]8360[/ATTACH]
      Thanks any way dude.I know other solutions but it's not service mode options i can't believe.
      • charm5496
        • 2387
        i searched through the service manual and asked a couple of my techs to verify and none of us can remember a service mode to open the doors. If I find anything I will post back.
        • charm5496
          • 2387
          this might work for you.
          COPIER>OPTION>DSPLY-SW> T-CRG-SW. Set T-CRG-SW to a 1
          this puts an option here SETTINGS AND REGISTRATION> ADJUSTMENTS/MAINTENANCE> MAINTENANCE> REPLACE SPECIFIED TONER
          so you can open the toner door without using the wrench.
          • zoraldinho
            • Mar 2008
            • 5015
            I aprishiate that.
            • charm5496
              • 2387
              you are welcome my friend
              • teckat
                • 16083
                In Service Mode Level 2 make the following change. COPIER>OPTION>DSPLY-SW> T-CRG-SW. Set T-CRG-SW to a 1.
                Exit Service Mode and perform the following:
                In User Mode, enter SETTINGS AND REGISTRATION> ADJUSTMENTS/MAINTENANCE> MAINTENANCE> REPLACE SPECIFIED TONER.
                ADD ON TO CHARM5496-reply
                Physically open the outer toner cover. From the drop down menu, select replacement not needed, then select which toner doors you want to open. The Blue remove toner cartridge button on the bottom of the screen will now become active.
                After pressing the blue button, a message will appear; "the selected toner can still be used do you want to replace it? At this point, select YES. The toner doors will open at this time.
                • charm5496
                  • 2387
                  I knew there a was an article about it but all I could find was my notes
                  • Aries_1
                    • 42
                    Many thanks from sunny CA guys, this was something frustrating us for some time.
                    • teckat
                      • 16083
                      we forgot what the sun looks like here
                      • zoraldinho
                        • Mar 2008
                        • 5015
                        Thanks guys it's working.I read FM couple times but nothing found.
                        • charm5496
                          • 2387
                          who are the gays?! LOL
                          You are welcome zoraldinho
                          • zoraldinho
                            • Mar 2008
                            • 5015
                            I'm really sorry.ha ha ha.Never again,i promise.
                            • teckat
                              • 16083
