NP6230
  • bolabali
    • Feb 2011
    • 22
    NP6230
    I use NP6230 as a backup machine but it cannot pull paper from any (upper/lower) drawers, bypass is fine.
    And also wasteful of drum (no long life drum). almost one third part of A3 sized copied paper lightly black.
    What part inside there should I replace and how?
    • 23010
    100% agree. These feed units are definitely not as friendly as the newer ones. =^..^=
    • bolabali
      • Feb 2011
      • 22
      Thanks all,
      Unfortunately I'am +/-50km away from nearest local tech. I have cleaned up the blanking exposure assembly and resulted good copy but new problem 'E002' came up. Look like I have to wait a good tech willing to come.
      • teckat
        • 16083
        E002
        Thermistor (THI; poor contact,open circuit)
        Heater (Hl, H2; open circuit)
        Thermal switch (TSI ; open circuit)
        SSR (faulty)
        DC controller PCB (faulty)
        (Notes 1,2)
        When an error associated with ‘E002’ is detected, the copier turns off the power
        switch in 2 sec and and then turns off all power supplies.
        E000-E001-E002-and ‘E003-
        To reset these error codes, select
        ‘ERROR’ in service mode (*4*), and press the OK key. This arrangement is adopted to prevent the user from casually resetting the machine when the cause of the error is an open circuit in the thermistor, thereby protecting the rollers inside the fixing assembly against heat damage.
        If ‘E00-E001-E002-or E003’ is detected, the machine forces off the power switch in about 20 sec.
        In the case of ‘E202’ and ‘E204’, you may obtain details under ‘ERR’ in service mode (*I*)
        • bolabali
          • Feb 2011
          • 22
          Yes!
          Thanks teckat, I did *4* procedure and I can operate the machine now.
          I've read the service manual previously but I like *4* and postponed to check TH1 etc. (I'll check later)
          Thanks again.
          • teckat
            • 16083
            Originally posted by bolabali
            Yes!
            Thanks again.
