ir8070 e100
  • jiongpao
    • May 2009
    • 413
    ir8070 e100
    e100 on ir8070 BD PCB changed and error clear no hope. Do we really need to change laser unit? Or should i try to disassemble it and do some cleaning? The code come out once a while.
  • jiongpao
    • May 2009
    • 413
    Re: ir8070 e100
    i found out e100 can be solve by removing the laser unit and clean all around.
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1257
      Re: ir8070 e100
      Common problem on this model. You'll probably need to replace the laser if the problem isn't related to the door interlock switch or door mount assy causing problem with the shutter. Obviously....check the door 1st before ordering a laser.
      • V-P
        • Apr 2011
        • 679
        Re: ir8070 e100
        Usually when the laser is GONE it makes some noise.
        If you hear that noise than it is a good indicator to buy a new one.
