The paper has jammed CANON iR6570/5570
  • gensys
    • Jan 2011
    • 323
    [Jamming] The paper has jammed CANON iR6570/5570
    Display mess. >> Open the feeder cover (if any originals are left in the original feeding tray, remove them)
    But the paper in Feeder (ADF) is not present
    The Road will be Mastered by >>> the Going...
  • y_us1982
    initialize the feeder sensor. svc mde>feeder>function>init
    hope that solve yr prblm....
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5011
      tell as jam code.
      • gensys
        • Jan 2011
        • 323
        Hi my friends Zorald
        E000014-0000
        • gensys
          • Jan 2011
          • 323
          Thaks!!!!!!!!!!! Y_US1982
          • zoraldinho
            • Mar 2008
            • 5011
            E000014-0000
            Sorry friend but you give me an error for fixing motor.
            Check in service mode:
            COPIER<DISPLAY< JAM
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              E000014-0000
              If this is indeed the error, rebuild the fuser assembly. If turning the green knob on the fuser assembly feels erratic, there are flat spots on the rollers, and this can cause the E014's...
              • charm5496
                • 2387
                looks like there are two different issues going on for gensys. There E014 error and the ghost jams in the DADF. Curious if he is getting the remove jam after the machine power is cycled OFF/ON for the error code.
                • gensys
                  • Jan 2011
                  • 323
                  Copier<display< jam
                  code 0045
                  • teckat
                    • 16083
                    Copier<display< jam
                    code 0045
                    J0045
                    Level 1 - FEEDER>FUNCTION>SENS-INT in service mode
                    adjustment will indicate "OK!" if it ends normally.
                    • gensys
                      • Jan 2011
                      • 323
                      Hi <techkat> - my friend
                      After initialization of sensor controls the error passes but when the mashin reboots or joins - is switched off
                      again gives out an error 0014 even at disconnected ADF, can??? sets factory defaults may by?
                      Thanks !!!!!
                      • teckat
                        • 16083
                        Thanks !!!!!
                        E014 is a Fixing Unit error/check LFR/Fuser roller bearings
                        also check that the front door switch sitting correct.
                        Check & Adjust the magnet on the front door to depress the front door switch fully.
                        door switch not being closed correctly will cut the 24v to fix motor
                        • gensys
                          • Jan 2011
                          • 323
                          teck kat my fiend
                          see
                          Thanks for all
                          • mrfixit51
                            • Oct 2008
                            • 1975
                            As I previously stated,, the E014's are caused by the fuser, not a Document Feeder. As Teckat and I have stated, look to your fuser area for a solution...
                            • teckat
                              • 16083
                              U HAVE A FUSER ISSUE/
                              Either remove it to inspect-
                              or ignore it/ it's your choice
                              Flip a coin= Heads I Win/Tails U Lose
                              ERROR CODE:
                              E014-
                              0000 (fixing motor error)
                              After the fixing motor has gone on, the machine does not detect the phase lock signal for the fixing motor for
                              2 sec or more.
                              The PULL lock signal of the fixing motor
                              does not arrive for 2 sec even when the
                              fixing motor has been turned on.
                              - Check the connector for any fault in connection.
                              - Replace the motor. M3: fixing motor
