imageprograf w7200 firmware update troubles
  • mrfuser
    • 1617
    How do you update the firmware when machine won't go into service mode and just displays error code? I know there is a file you can use or a way to trick the machine, but can't seem to remember.
    This is a W7200. We really need version 2.12.
    Kelly
  • costd
    • Jan 2008
    • 409
    Last IPF I worked on was an 8000 and that was almost 2 years ago. Seems though that it is not service mode but download mode you want - soooooo, checked on Canon
    Question :
    How do you enter the Download Mode on the imagePROGRAF printers?
    Answer :
    For earlier W2200-Series models: (First, power off the printer)</U>
    Press and hold the UTILITY + SETUP + RESET buttons simultaneously, then press the POWER button. Release the buttons when the message "FIRMWARE UPDATE" appears in the display.
    For iPF W6200/8200 series models: (First, power off the printer)</U>
    Press and hold the PAPER SOURCE + ENTER + ONLINE buttons simultaneously, then press the POWER button. Release the buttons when the message "DOWNLOAD MODE" appears in the display.
    For iPF W6400/8400 series models: (First, power off the printer)</U>
    Press and hold the INFORMATION + STOP + OK buttons simultaneously, then press the POWER button. Release the buttons when the message "FIRMWARE UPDATE" appears in the display.
    For iPF models PRIOR to the iPF650/655/750/755: (First, power off the printer)</U>
    1) Press and hold the STOP & INFORMATION buttons simultaneously, then press the POWER button. Release the buttons when the message "INITIALIZING" appears in the display.
    2) When "DOWNLOAD MODE/SEND FIRMWARE" appears in the display, transfer the Firmware.
    For the iPF650/655/750/755 series:(First, power off the printer)</U>
    1) Press and hold the STOP & NAVIGATE buttons simultaneously, then press the POWER button. Release the buttons when the message "INITIALIZING" appears in the display.
    • teckat
      • 16083
      Kelly
      Look at this link below>>>>>
      Canon in South & Southeast Asia
      For BJ-W7200/ W7250
      For firmware version 2.00, please install printer driver version 1.60 and above (for Win95/98/Me/NT/2000/XP), and printer driver version 1.41 and above (for Mac OS/ OSX)
      1.
      Unzip the downloaded Firmware Update Tool ("w7200_firmwareV200.exe" / "w7200_firmwareV200.hqx" / "w7200_firmwareV200.sit").
      2.
      Double-click "CNWFUT01.exe"
      3.
      Follow the message on the screen to update the firmware.
      • mrfuser
        • 1617
        Okay, updated firmware, all went fine. Strange thing is that if you do NOT put margins in a custom size setting of 36 x 24 you get wide bands of black print randomly on pages. Add margin and works perfect. Very strange these here beasts I'd say!
        Kelly
