canon iir 2200 grayish pages
  • ochnerknocker
    • Jun 2025
    [CQ] canon iir 2200 grayish pages
    new to copy world,working on ir2200 getting gray backround also print very dark
    changed image drum no change
  • ochnerknocker
    genuine canon drum and toner
    not familiar with 101 counter?
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      Copier test prints from Service Mode,,, are they good and only copies have the problem?
      • sharath9848
        • Jul 2010
        • 6
        Clean The lens And Camera and Laser Unit Hope Problem Will be Solved
        • ochnerknocker
          copies,pc prints,prints from ser mode all do it
          there is a 1/4 inch border around whole page that stays clean
          • ochnerknocker
            122k prints
            • D_L_P
              Self Employed
              • Oct 2009
              • 1196
              Originally posted by ochnerknocker
              changed image drum
              Did you change just the drum? The charge roller and blade needs replaced with a drum too.
              Check the developer bias tab. Make sure it isn't coated with black grease or bent.
              • ochnerknocker
                i have charge roller i was going to try//i will check the developer///can you tell me more about the blade
                • mrfixit51
                  • Oct 2008
                  • 1975
                  Simply replace the drum cartridge with a new cartridge is the easiest way to resolve your issue. Pieces parts approach takes more time, and time is money. Also, there is a warranty on new drums, whereas if you take the individual parts approach, establishing warranty on those items would require swapping out all the individual parts, drum-charge roller-blade, to honor an after market drum warranty...
                  Just my Saturday's two cents worth... ;-)
                  • ochnerknocker
                    drum cartridge was changed,i was going to change transfer roller
                    • mrfixit51
                      • Oct 2008
                      • 1975
                      By "cartridge", are you referring to the entire drum assembly, as in an out of the box from Canon drum assembly, or are you referring to a drum cylinder? And if you have replaced the entire drum assembly, why would you be putting a charge roller in it?
                      Just trying to stay on the same page with what has already been tried...
