IR3300 waste toner full message
  • bartman
    • Sep 2010
    • 50
    Usually I Get the E0019 code and upon cleaning the window of the waste container it goes away. I was just at this account two weeks ago and the customer is complaining about the "Empty The Waste toner" message already. Does the window on the waste toner bottle become discolored over time and need to be replaced? I have seen some machines where techs have drilled out the window on the bottle. Does the waste toner sensor S-2 go bad very often? Thank you for any input.
  • CT Copier Repair
    • Mar 2010
    • 304
    waste toner sensor dislodged? the toner auger can get filled and the sensor can get snapped out its holder. Need to take the rear copver off and look
    • D_L_P
      Self Employed
      • Oct 2009
      • 1196
      I've seen some techs drill out the hole as well, but IMHO that makes it worse since usually just cleaning the sensors takes care of the problem.
      You need to push the black guide back in the machine as if the bottle is in to really see the sensors. Then there are 2 little bulbs that need dusted off, one sending light and one receiving it. They must be very sensitive since the slightest amount of toner will set them off.
      • Brian8506
        • 1665
        Is the neck of the bottle getting dirty?
        • bolabali
          • Feb 2011
          • 22
          pull out the waste toner bottle and clean the neck of the bottle and restore it back.
          See the same thread previously submitted.
          • teckat
            • 16083
            Check -COPIER>I/O>DC-CON><DC-CON (2/7)>
            I/O address-P008-2
            Waste toner case full sensor > 1: full
