canon ir-5570 screen
  • albertojp
    [Dead] canon ir-5570 screen
    I have a problem with my screen on my Canon IR-5570 copier is as out of calibration and I can not selecting options such as selecting the paper or any option which he gives. I can do?
  • doktor
    • 215
    http://www.copytechnet.com/forums/ca...iss-touch.html
    • charm5496
      • 2387
      service mode>copier>function>panel>touch check
      Touch the cross hatches with the stylus to recalibrate the screen. there are times when this doesn't work and you have to replace the LCD
        • 16083
        TOUCHCHK Use it to adjust the coordinates of the analog touch panel.
        Procedure
        - Use it to match a specific point of the touch panel and its
        coordinates on the LCD.
        - If you have replaced the LCD assembly, be sure to execute this
        service mode item.
        1) Select [TOUCH CHECK] to highlight, and press the OK key.
        2) Press the 9 + symbols that appear on the touch panel to make
        adjustments
