I'm trying to fine out if this copy machine has an auto turn on / auto warm up feature. They are asking be if there is a way to have the copier turn its self on so when they get to work it is already warmed up. i know there is a way to make it turn its self off, but i couldn't find anything about turning its self off.
Canon ir C3200 auto start?
there is not an auto on feature for this model, but if they have a fax you can set the machine to run a report every morning at specified time to "warm" the machine up and cut down on the customers wait time while it is warming up.Accidents don't just happen. They must be carelessly planned. -
This machine doesn't have the fax option so i guess they'll just have to deal with it for lack of a better word.Comment
Leave Main power switch on
Keep the machine on power save mode, low power mode, or sleep mode
set low power mode /& sleep mode to 4 hr
1. Standby Mode
In standby mode, the machine is in operation or is ready to operate, with all its parts
supplied with power.
2. Power-Save Mode
The term “power-save mode” is used generically to refer to the following modes, in
which the machine is supplied with power differently than it is in normal mode: power save,
low-power, sleep. A shift in the direction of ‘present power-save mode’ to ‘low power
mode’ and then to ‘sleep’ mode occurs automatically.
• Power-Save Mode
Shift: A shift to power-save mode is initiated only in response to a press on the Save Power button on the control panel.
Description:• Low-Power Mode (factory setting)
This mode conforms to the standards under Energy Star.
Shift: A shift is made only in response to the passage of time (auto low-power shift time) selected in user mode.
Description:• Sleep Mode (sleep mode 1 or sleep mode 2)
Shift: A shift is made in response to the passage of time (auto sleep shift time)
specified in user mode or in response to a press on the control panel software power switch.
Description: In sleep mode 1 (relatively higher power consumption), the fixing assembly
is totally deprived of power. The DC controller PCB, however, remains supplied with power.
In sleep mode 2 (relatively lower power consumption), on the other hand, the printer unit (including the fixing assembly) remains OFF; the main controller PCB is supplied with all-night power**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
