Parts number for iRC 5185
  • Apach
    • 157
    Hello,
    I need a part number for the next piece of equipment iRC 5185i :
    Transfer belt
    Cleaning blade
    and for this (I dont know how to write) rubber ?
    Tnx
    There is no stupid question, just stupid answer
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    FG6-8989-000 is the cleaning blade assembly...
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5006
      Originally posted by Apach
      Hello,
      Transfer belt
      Cleaning blade
      [ATTACH=CONFIG]8587[/ATTACH]
      Tnx
      Fig.531 FG6-8989-030 1 TRANSFER CLEANING ASSEMBLY
      1 FS5-6957-000 1 WASHER,WAVE
      2 FB6-3113-000 1 COVER, CLEANING
      3 FF6-2032-000 2 SUPPORT, BLADE SWING
      4 FS1-9010-020 1 SCREW, STEPPED, M3
      5 FS7-2840-000 2 SPRING, TENSION
      6 XA9-0624-000 9 SCREW,M3X4
      7 FF6-2393-000 1 SEAL, FRONT
      8 FF6-2394-000 1 SEAL, REAR
      501 XB1-2300-407 4 SCREW, BH3X4 (S)
      502 XB4-5300-807 2 SCREW, P, M3X8
      Fig.530 FM2-5365-010 1 INTER. TRANSFER BELT ASSEMBLY
      1 FC7-0091-000 1 BELT, ITB
      2 FB6-6380-000 1 ROLLER, TENSION
      3 FB6-2934-020 1 ROLLER, TRANSFER, SECONDARY
      4 FB6-2936-000 2 BUSHING
      5 FB6-2938-000 2 COLLAR, LIMIT
      6 FB6-2939-000 4 PLATE, CONTACT
      7 FM3-5438-000 1 BELT COVER ASSEMBLY OLD TYPE
      7 FC9-0271-000 1 COVER, BELT NEW TYPE
      8 FB6-2941-000 1 PLATE, GROUNDING
      9 FC7-1461-000 1 HANDLE, FRONT
      10 FB6-2944-010 4 BUSHING
      11 FB6-2945-010 4 BUSHING
      12 FB6-2947-000 1 PLATE, GROUNDING
      13 FB6-2948-000 1 SPRING, LEAF
      14 FB6-2951-000 1 COVER, GEAR
      15 FC7-2748-000 1 ROLLER
      16 FB6-2958-000 1 PLATE, GROUNDING
      17 FB6-2974-000 1 SCRAPER
      18 FS6-1062-000 2 BUSHING
      19 FS7-2781-000 2 SPRING, COMPRESSION
      20 FS7-2782-000 8 SPRING, COMPRESSION
      21 FS7-2783-000 1 SPRING, COMPRESSION
      22 FU7-0406-000 1 GEAR, DRIVE
      23 FU3-0267-000 1 GEAR, 18T
      24 FU3-0268-000 1 GEAR, 40T
      25 FC7-4811-000 4 ROLLER, TRANSFER, PRIMARY
      26 XG9-0596-000 2 BEARING, BALL, 6801ZZPSH44M,
      27 XG9-0415-000 1 BEARING,BALL,688AZZ1*MC3JD4ML
      28 FG3-2365-020 1 CABLE, VARISTOR
      29 FB6-2953-000 1 HOLDER, CONTACT
      30 FB6-2954-000 4 CONTACT
      • Apach
        • 157
        TNX
        • zoraldinho
          • Mar 2008
          • 5006
          TNX
          • teckat
            • 16083
            Do not replace that sticky felt covering/ below rubber sweeper
            gut printer and scrape it off/ u do not need it
