ipass c1-e747
  • roho
    • Mar 2009
    • 844
    [Error Code] ipass c1-e747
    error code 747- sub code 8000. Not in my manual. Has anybody had this code up before?
    Was hoping to get some info before I go there mon morn, thanks!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5017
    Check connectors on main controller, turn of and on machine and continue with making money.
    • teckat
      • 16083
      u mean imagePress C1
      or the imagePass C1 Fiery ???
      always post the entire code> as in Sub code> E747-XXXX ??
      1. Remove SDRAM from the Main Controller PCB.
      2. Wipe the terminal of SDRAM with lint-free paper impregnated with alcohol, and then re-fit the SDRAM.
      There is an error in the ASIC for image processing or in the ASIC for memory
      control/communication control.
      There is an error in IC1015 (ASIC for image processing) or in IC1012 (for memory control/ communication control) on the main controller PCB (e.g., image data transfer error)
