IR6570 E840
  • repeatcopiers
    • Sep 2008
    • 591
    IR6570 E840
    Ok, IR6570 had E014, tech replaced lower bearings then machine threw E840.....could something not be put back right???? Any ideas?
  • gensys
    • Jan 2011
    • 323
    There is a shutter error
    - Check the connection of the connector
    of the shutter motor and the shutter HP
    sensor.
    - check the mounting of the pin used to
    match the shutter gear phase of the fixing
    unit (See descriptions under "Points to
    Note When Mounting the Fixing Roller.")
    - Replace the shutter HP sensor and the
    shutter motor ??????.
    The Road will be Mastered by >>> the Going...
    • gensys
      • Jan 2011
      • 323
      It is standart Error for iR
      To check up 12/24 volt on the motor
      U HAVE A FUSER ISSUE/
      Either remove it to inspect-
      or ignore it/ it's your choice
      Flip a coin= Heads I Win/Tails U Lose
      ERROR CODE:
      E014-0000 (fixing motor error)
      After the fixing motor has gone on, the machine does not detect the phase lock signal for the fixing motor for
      2 sec or more.
      The PULL lock signal of the fixing motor
      does not arrive for 2 sec even when the
      fixing motor has been turned on.
      - Check the connector for any fault in connection.
      - Replace the motor. M3: fixing motor
      http://www.copytechnet.com/forums/ca...-5570-a-2.html
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        Shutter HP sensor connector would be my bet, as if the lower fuser was the only thing worked on, the shutter assembly should still be in time. The connector is at the 6 o'clock position of the fuser assembly, and the small connector might have been overlooked.
        • repeatcopiers
          • Sep 2008
          • 591
          Someone mentioned a copper piece that runs thru the fuser unit that warps over time could cause this code......have you heard of this and if so, do you have a part name or number?
            I've not had it warp but toner does does get in there, harden up and cause friction.
            When you turn the machine on you should hear a rattle sound as the shutter finds its home position but this should only last for a few seconds.
            But as said before to change the lower bearings you don't need to touch this so its probably a missed connector.
            • teckat
              • 16083
              what about calling back this expert tech to investigate your issue ???
              The E840 code relates to a fixing unit shutter position error condition. The error code can be generated because the shutter motor is not moving the shutter to the sensor detect position or because the shutter position sensor is not detecting the proper movement of the shutter.
              The shutter movement may be inhibited by a bent Rear Shutter Gear Stopper (Part number FC6-3528-000).
              improper position of the stopper.
              proper position of the stopper below>
              The stopper is located on the rear of the Fixing Assembly pictured below.
              • mrfixit51
                • Oct 2008
                • 1975
                If only the lower end of the fuser was rebuilt, I imagine the shutter is ok, unless it got messed up during removal. I myself have forgotten to plug in the sensor I mentioned earlier...
                • repeatcopiers
                  • Sep 2008
                  • 591
                  Thanks for all the help. The wire was broken on the connector going to the sensor. Thanks for pointing me in the right direction!!
                  • teckat
                    • 16083
                    • mrfixit51
                      • Oct 2008
                      • 1975
                      You are welcome!!
                      • gifter
                        Re: IR6570 E840
                        i have the same problem with my canon but that Rear Shutter Gear Stopper is ok,
                        what else can be broken?
                        • Brian8506
                          • 1665
                          Re: IR6570 E840
                          Check upper bushings also. I've had them break and cause this code.
                          • gifter
                            Re: IR6570 E840
                            Could you give a picture of that?
                            • teckat
                              • 16083
                              Re: IR6570 E840
                              Also check this------
                              Check for paper wedged in the rear frame connector that the fuser plugs into.
                              A piece of paper found in the connector can be very small, blocking only one pin within the connector. It may be necessary to remove the Fixing/Feeder Frame Assembly to see and remove paper from the connector on the rear frame of the machine.
