Canon IR C3200 - Error E000020-02b0
  • Suke
    • Aug 2025
    Hi,
    Received this error from our own copier... but i don't have manual for this one and i don't have that much experience from servicing copiers (just printers).
    I've got some hints that this has got to do something with one of the drums, but which one ?
    Could someone help me out here?
    REALLY appriciated
  • gazza
    • Feb 2007
    • 15
    E020 fault with drum / developer
    the magenta drum needs replacing
    xx=01 : y
    xx=02 : M
    xx=03 : C
    xx=04 :BK
    • Suke
      Ok,
      • Suke
        Help,
        Now that i have finally changed that magenta drum, i receive error E000020-0424.
        Do i need to replace black drum also ?
        • welshman
          Technical Support Manager
          • Oct 2007
          • 91
          replace them all
          i would replace them all you will get one error after the other
          change them as a set also check the fuser unit that will go next
          regards steve
          • Suke
            Ok, will do
            Thanks Steve
            • Irish
              • 110
              Go into service mode and chech under misc. It will give you reading for drum life Canon call it % but its not exact ... I would not let this exide 250 as drums start to drop toner and cause transfer belt slippage causing registration problems .. Mag is the most troublesome drum . (%)count carries reading with it and resets to 1 when you install a new drum .. New software has helped drum life issues but seems to double reading on a once off on drums installed during flashing .. Good Luck
