Hello, is one able to rebuild a fixing assembly or do you have to replace the whole unit?
5180 fuser
**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
you now buy the entire unit/ Refurbish or New
You don't play around> other parts, like the two small gear units also wear down on gear teeth
it was no picnic replacing that upper part, only to discover that gears were and issue also
Time is Money**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
