Canon SMTP Authentication
  • joelio18
    • 11
    Canon is one of the most popular brands we sell however they seem to have an issue with SMTP Authentication.
    Does anyone know where to set the SMTP AUthentication or where to check if that is a feature of the copier???
    ...I'm currently working on an IR-2220i
    Last edited by joelio18; 11-09-2007, 08:53 PM. Reason: Forgot to mention the model
    • 22932
    I haven't looked at a Canon in ~5 years, but I'd start with the web page. It's a whole lot easier than digging through the menus on the copier screen.
    • phildmatthews
      iR2220i
      From memory, depress the additional functions button (head with star in it) Go system>network>page down to email/ifax enter, you will need either the IP address of theSMTP server or Name plus an address for the copier,i.e. iR2220i@*******. You will also need the Domain name for the network. System>network>TCP/IP. Always exit each page to retain info and PO/PO. If you enter the IP of this machine in your web browser you should be able to view the remote user interface which can make things easier. To update the m/c after making changes hit the refresh button in the top RH corner of the RUI screen.
      • Christan
        • 37
        SMTP Authentication
        There is no SMTP Authentication for IR 2220i( this include ir i series), it is only available on the newer canon model (IRC and the IR70 series onward).
        • joelio18
          • 11
          firmware update
          Is there possibly a firmware update to add authentication?
          Also, does anyone know what "SMTP Receipt" is?
          • Christan
            • 37
            Currently no firmware update add SMTP authentication to the copier.
            "SMTP Receipt" allow the copier to recieve I fax
