effect of heavy paper on canon 4570
  • sundeep202
    • Oct 2010
    • 26
    hi frnds
    i have a canon 4570. i am using thick density paper ie. 105gsm instead of 75gsm which is normally used. i want to know if this paper will affect my machine in any way? plz tell me. i am using this paper bcoz i am got it at the same price that of 75gsm.
    also that my prints are faded in the upper portion of A4 page. should i change my drum or anything else may be?
  • teckat
    • 16083
    Originally posted by sundeep202
    hi frnds
    imageRUNNER-4570/3570/2870/2270
    Stack Bypass=Paper Weight: 17 to 32 lb bond (64 to 128 g/m2)
    Paper Drawer=(17 to 20 lb bond (64 to 80 g/m2)
    Paper Deck=(17 to 20 lb bond (64 to 80 g/m2)
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      As Teckat pointed out, that weight would really not be supported from the cassettes, but you can run what you like in your machine. What comes to mind to me is increased wear in the feed rollers as well as fuser wear.
      • sundeep202
        • Oct 2010
        • 26
        thanks dear for ur reply.
        • costd
          • Jan 2008
          • 409
          Should go without saying but - make sure you set the paper type and only use the bypass.
