IR7200 Error E225
  • jvargas
    • May 2009
    • 44
    [Error Code] IR7200 Error E225
    I have ir7200, with e225, i change xenon lamp, ccd, inverter, the flex or ribbon, the glass, all the scanner system and nothing, i still have e225, the lamp is turn on and the progress bar arrive to 3/4 in the screen, its happen when the customer move the machine in his car for 50 km, it work with 3 copies, and error appear, can somebody help me please, thanks.
    • 16083
    did u check the READER CONTROLLER connectors ???
    • jvargas
      • May 2009
      • 44
      yes, i put other and nothing, and all the things changed are working in the other machine,
        • 16083
        need to be patient and re-check wiring to controller
        make up a procedure check list to follow
        • jvargas
          • May 2009
          • 44
          I will work in it next week, thanks.
          • jvargas
            • May 2009
            • 44
            I fixed the problem, only buy and change all the assembly, the scanner, the machine is working
              • 16083
              good luck, use old one for testing
