5055 0203 jam code
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    5055 0203 jam code
    I have an ir 5055 having a 0203 jam code a couple times a day. I have replaced the drive motor M25, PS24 and PS28. Checked the springs on the door too.
    It doesn't matter if it is feed from PD1, PD2 or duplex. Any ideas?
  • teckat
    • 16083
    That is a stationary jam at PS24
    Check the rear spring for vertical guide located between the door and guide -
    Make sure it is not out of position causing slight uneven pressure.
    *Note-Spring is located behind this guide plate (red arrow).
