Hi all
I have had little experience with these copiers so hoped someone could shed some light on a problem I have.
The copier switches on ok.
Then if you start to copy a document, the scanner platen moves as it should, the paper in the cassette is picked up then all motion stops and it swithes itself off.
The last digits I can see fading away on the display is a small 'A' in the left corner and the letter 'E' in the right.
I fooled the left door to check if the fuser was warming up and found it was stil cold.
I have checked all the connections to the fuser and can only assume the copier is switching off as the fuser is failing to warm up?
Can anyone help?
Many thanks
Can anyone help?
Many thanks
