Changing Drum in Canon IR5000
  • Canonman10
    • Oct 2010
    • 9
    [Misc] Changing Drum in Canon IR5000
    Can someone briefly explain how to change drum in canon IR5000?
    Thank you
    • 23008
    Briefly ... OK.
    It's been a number of years. This is what I remember:
    Remove toner hopper.
    Remove developing unit through right side door.
    Remove drum shaft retainer screw and retainer.
    Pull out transport drawer. Lay some white paper on it.
    Carefully slide out drum drawer.
    Be extremely careful with that drum. It'll take two paychecks, maybe three to pay for a replacement if you scratch it. If you aren't a professional I advise against doing this yourself. =^..^=
    • teckat
      • 16083
      Thank you
      If u are not a tech. / please call for a trained tech on this model
      • skkn
        I agree with this
        and learn with tech, sometime I use Camera/VCR
        for reference next time I need to do by yself
        • waffu22
          • Jun 2009
          • 95
          If you have confidence with yourself, why don't you try?
