Sir,
Canon IR 3320i poor fixing
17 - 20 pound in cassettes, and 17 - 32 pound in bypass.
20 pound is 80 g.s.m., so to answer your question, NO.
Run heavy stock thru bypass so you can tell the copier it is heavy, and copier can make some adjustments to the fuser speed and temp, and transfer voltages to handle the heavier stock..."Once a King, always a King, but once a Knight is enough!"
