copies have C background with correct laser settings in machine.Different laser works ok.On older CLC copiers the lasers levels could be adjusted.As I was about to throw the laser assembly in the garbage,I noticed 8 potentiometers on the laser pwb.Has anyone tried adjusting one of these?
Canon C5180 laser adjustment
They can not be adjusted in the field for background issues.
U can adjust the Cam position on each for image offset issues.
Image offset Laser issues can also be adjusted in service mode.
COPIER>FUNCTION>LASER
LD-ADJ-Y/M/C Making the tilt correction motor return to the initial position automatically. in Level-2
u can swap them to isolate an issue with a different color/ but u need to put in settings for the swapped color.**Knowledge is time consuming, exhausting and costly for a trained Tech.**
