imagePRESS C1/C1+ Cross Feed Banding / Pitch Lines - Asked to Re Post Pub. from 2010
    • 16083
    [CQ] imagePRESS C1/C1+ Cross Feed Banding / Pitch Lines - Asked to Re Post Pub. from 2010
    Publication describes procedures to troubleshoot the cause of and actions to take to
    minimize Cross Feed Banding / Pitch Lines on the imagePRESS C1.
    imagePress C1 C1+ TP10-2.pdf
    here is the Flywheel tech pub.
    C1 C1+ Flywheel TP08.pdf
    on some Machines it works/ others no help, trial & error
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5006
    I'm canon gold partner but i have one nice picture for canon for this remedy for c1.
    • direxiondm
      Cross Feed c7000VP
      does this work for imagepress c7000VP. We have had cross feed forever. No solution availlable with techs!
        • 16083
        Originally posted by direxiondm
        Have u run some single color PG5 Prints to isolate Color ???
        Pitch Lines and Gear Noise
        Pitch lines from front to rear in one or more colors. A gear noise is present in the corresponding Developer Unit.
        Solution :
        The issue may be with the developer drive gears skipping. To help determine this is the issue; try running a COPIER>FUNCTION>INSTALL>STIR-4 with the Developer Unit disengaged from the drum.
        If the noise is absent try the following:
        Replace the 35T Gear (FU6-0363-000) in the Developing Drive Assembly and the 41T Gear (FU6-0368-000) in the Developer Rail Assembly.
        With the Process Unit removed, lift the rear of the Developing Rail Assembly to provide a better mesh for the drive gears.
        • direxiondm
          Hi teckat,
          Will lOok at this in the morning time difference is 8 hours So its almost nine om here
          • zoraldinho
            • Mar 2008
            • 5006
            NO it's doesn't work on c7000VP.It's totally different structure.What kind if issue do you have?I'm very interesting.Please post image.
              • 16083
              there is a pitch line C7000vp Tech Pub investigation check I posted above/ sometimes u can't here the gear noise
