5020 hard disk
  • misseducation
    • Aug 2025
    5020 hard disk
    Does anyone know how to repair the broken 5020 hard disk...?
    need help here..
  • CT Copier Repair
    • Mar 2010
    • 304
    yea
    call a canon tech
    need an hadd the sst tool and firmwae
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      What indication do you have that the hard drive is not operating properly?
      And as CT Copier Repair has indicated, you would need a new hard drive, not just any hard drive will work, Service Support Tool, and the System Software for the 5020.
      • cableties
        • 35
        Latest V59.51
        • misseducation
          i already have the working hard disk, and the sst v3.35...
          can i clone the hdd..?
          • teckat
            • 16083
            what was Error code ??
            if u have the SST - U should have the 5020 firmware loaded
            u have a working HDD from where ? another 5020 ?
            • misseducation
              Sorry all.... i mean 5570 hard disk, not the 5020...
              I have SST, and i have the other hard disk from the other machine...
              And i want to repair hard disk from the broken machine...
              • spectraindo
                • May 2008
                • 313
                iR5570 HDD is not the same as iR5020, get a proper HDD (3,5" IDE HDD, Seagete ST340014A or ST340015A will work).
                • misseducation
                  The error is 602-001...
                  Yeah its different..
                  I have one broken hard disk and one hard disk that working properly from the other machine.
                  I already connect to pc, but the pc won't detect it.
                  What should i do..?
                  • spectraindo
                    • May 2008
                    • 313
                    Get a new HDD ,install on the machine and install the system software using SST.
                    On iR5020 you can connect to PC using Paralel cable or crossed UTP cable with fixed IP 172.16.1.160.
                    • mrfixit51
                      • Oct 2008
                      • 1975
                      SST has nothing to do with disk cloning. If cloning is to be attempted, you need a working hard drive from an exact match to your copier, a 5570 will not work, nor will a 5000, or anything else except another 5020. Find out what make/model hard drive you already have in the copier, buy one, use SST to then Partition/Format that drive, and then SST can load the System Software onto the drive.
                      Until you have those 3 things, you are just whistling in the dark.
                      Windows operating system on a PC will not recognize the partitions, as their format is different than that used by the PC.
                      • madu132
                        • Dec 2008
                        • 65
                        if you want to clone it, use cloning software like norton ghost or else...
