Canon iR2200 jamming and smearness! Help
  • david
    • Aug 2025
    [Jamming] Canon iR2200 jamming and smearness! Help
    Good morning members!
    Canon iR2200 keeps on jamming and smearness on every other inch, replaced the fuser unit, fransfer belt, drum unit, re-set the hard drive with good working unit, still jamming and smearness apears, No error code, what do i need to do next?, Immediate help will be greatly appreciated! thank you super techicians ^_^
    David
  • teckat
    • 16083
    David
    what about a Jam Code/ check Jam Log
    is it jamming at Fuser ??
    Check the actuator flag for PS13 (Fixing/Feed sensor) at the exit side of the Lower Fuser roller
    PS13 flag is FB6-2860-000-Check PS13 in IO mode. Service mode>DCON>PO15 bit 5.
    Check if the rear bushing below the fixing assembly is out of position causing uneven pressure to be applied
