Duplex Color Image Reader Unit- A1/B1/C1
    • 16083
    [Misc] Duplex Color Image Reader Unit- A1/B1/C1
    Measure Against Damage to the Lead Edge Corners of Originals
    Technical Publication describes how to minimize damage to the corners at the original document lead edge.
    TP11-8.pdf
    Document.pdf
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
      • 16083
      Copier/Printer Service Technician
      The Copier/Printer Service Technician repairs and maintains Copier and misc office equipment at the customer's office; plans copier service work; maintains copier parts and supplies inventory; maintains customer rapport; determines causes of copier failure; corrects copier malfunctions; completes preventive maintenance; verifies copier functioning; documents service actions; updates job knowledge; accomplishes organization goals.
      This job never gets boring
      Experience with the tools required for mechanical & electrical inspection .
      -SCREWDRIVER & ELECTRICAL TAPE-Sets clear goals and pursues them until desired results are achieved.
      -NO BREAKS/ NO LUNCHHas excellent attendance and can handle responsibility.
      -NO SICK TIME / NO VACATIONSDemonstrates flexibility by adjusting readily to changing priorities.
      -OVERTIME IS REQUIRED-
      -SHARPENING PENCILS/TAKE MESSAGES/SEND MESSAGES/ADDING PAPER &
      TONER/CLEANING THE GLASS/CLEARING JAMSSpeaks clearly and effectively in a variety of settings.
      -UH'-DUH, WAD U SAID, ID BE OK FUR NOW
      - Excellent Customer Service skills required.
      -DON'T WORRY I BE TEHR, YEAH I BE TEHR , HOLD ON, KEEP HOLDIN' ,
      SORRY AM TRAPPED ON FREEWAY, DOG ATE MY TOOLS
      • butitsmyfirstday
        • Feb 2011
        • 60
        Re: Duplex Color Image Reader Unit- A1/B1/C1
        Are there part numbers for the entire A1/B1/C1 unit? Customer tried to move machine on their own and decided a ratchet strap across the top was the way to go...
          • 16083
          what is your printer model ????????
          A1
          A1/C1
          B1
          or
          C1
          what do u have ?
          Look on the plate on back of unit
          • butitsmyfirstday
            • Feb 2011
            • 60
            Copier is an imageRUNNER Advance 7065. Forgot to check the reader model number before I left so I'm just trying to get part # to check for a ball park price to replace unit.
              • 16083
              I believe u have >>>>
              on that series-------
              u may need to get/order from Authorized Canon Sales Office in your area
              found one online---------
              Canon Duplex Colour Image Reader Unit-A1 (3689B003AA)
              Free Delivery
              u can search Google using Canon OEM-#
              3689B003AA
              what exactly is damaged ????????? --Frame/Tray ?
              • butitsmyfirstday
                • Feb 2011
                • 60
                Frame, glass, tray, multiple plastic panels, etc... Thanks for the link Teckat, as usual you go the extra mile.
                  • 16083
                  Glass is separate order /good luck/ take your pick for your location
                  FM3-5495-000 1 GLASS, COPYBOARD -A
                  FM3-5493-000 1 GLASS, COPYBOARD -A/B
                  FM3-5494-000 1 GLASS, COPYBOARD -INCH/A
                  FM3-5496-000 1 GLASS, COPYBOARD -INCH/A/B/K
                  see
                  GLASS,EXTERNAL COVERS, PANELS, ETC..pdf
                  • butitsmyfirstday
                    • Feb 2011
                    • 60
                    Awesome sir, you do indeed rock!
