canon clc 1180 E072 0001 help me please
  • xximhxx
    • Apr 2011
    • 24
    dear all
    my canon clc 1180 after fill black toner it printed some papers then appear E020 Error
    then i cleaned with paper inside machine then appear E072 0001 error
    when copying only black it work but when copy or print in CYMK this error appear
    any suggestions?
  • teckat
    • 16083
    Originally posted by xximhxx
    dear all
    any suggestions?
    Check both sides of all the door switches for voltage. A switch that is failing will drop the supplied voltage 3 to 5 vdc. Replace the switch. Check both SW4 (Left front cover switch) and SW5 (Delivery Cover switch).
    when u pull off covers to check switches, make sure they close correctly - when door is shut
    Check the Transfer Cleaning Assembly , The housing could be warped or the bearings could be seizing which may cause the error.
    E020 could be many things/ what is sub-code ??
    • xximhxx
      • Apr 2011
      • 24
      thank you for reply but can you explain with pdf file or picture
      because i dont know where to change volt and sw4 cover etc....
      • xximhxx
        • Apr 2011
        • 24
        it was E020 04E0 but now not appear.only now e072
        • xximhxx
          • Apr 2011
          • 24
          the finaly error is (( E072 0202 ))
          anyone can help
          • teckat
            • 16083
            it is tough to get support on a 9 year old printer, that is not supported by Canon
            this CLC1100 Series has too many issues to go over on a support site
            E072 can be caused by many issues>
            DC fuse board,Transfer Driver PCB, Transfer Driver Motor or the associated Transfer Driver wiring harness it may be necessary to replace the DC Driver PCB.
            Your Drum cleaning blade unit could be locking u Transfer Drum
            • xximhxx
              • Apr 2011
              • 24
              could you reply on my private msg please
              • teckat
                • 16083
                PREVENTING E072 - this is an old pub.
                There is a possibility that the E072 error code can be caused by an accumulation of toner or starter inside the Transfer Frame Connector 2 (J544). This connector supplies the signals for the Transfer Drum Cleaning Assembly. If the E072 error code is encountered try cleaning any toner or starter that may have built up in or around this connector, which is located at the rear of the copier and at the rear of the Transfer Frame Assembly.
                Female Transfer Frame Connector 2 (J544)
                located at back of copier{above}
                Male Transfer Frame Connector 2
                located at the rear of Transfer Frame Assembly
                the transfer drawer connector becomes more prone to poor connection and breakage/ In some cases, communication failure with the main unit results in error E071/E072 being displayed.
                U could also have a bad FUSE BOARD/
                FU903 on the DC FUSE PCB
                U can short out the start signal for Polishing Cleaner Motor M8, because the start timing sometimes locks up the Transfer Drum
                think it is from the two pin
                24v RED line to the Orange two pin connector
                check that copper tab plate to Transfer Drum Gear/ it bends out of position
