canon iR 8500 starteing light copy
  • kingpd@businessprints.net
    • 919
    #16
    Wooden laminate flooring shouldn't be a problem. It's always good to know the electrical outlines when plugging these machines in. It can give you some ease and eliminate headaches. I was in one office once in a home where you would get static shocked quite a bit too frequently. I remember touching a pc and it never working again.
    Had an IR 550/600 with a problem once on a carpet. Moved it and it worked better...this was after the primary corona and transfer assembly was replaced. Also had the customer upgrade their breaker to a 20 amp, was using 15 amp breaker which was ok but not recommended. Better power and less static is better with the paper too.
    If all else fails, after you change all the charge assemblies, transfer units, etc., maybe get the power board tested especially if manually adjusting the power levels to things such as the wires and lasers just doesn't work or only does a temporary fix. Eventually the power board can fail. Sometimes they can be repaired too.
    Try to test and eliminate the easy and cheap things first methodically and logically...because it can get time consuming and expensive replacing all the electrical related stuff.
    Originally posted by Matoku
    Hi Kingpd,
    you mentioned " on carpet floor" how about wooden eleminated floor? is it would effect also? if so, Am I need to use extra earthing cable (wire) for grounding the machine?
    20yrsexp> ir8500 tr-1 & TR-2 setting default is 531. And this I think Too much if I set to 200.
    I worried it will sparking and demage the drum as well.
