canon iR 8500 starteing light copy
  • nizam
    • Mar 2011
    • 40
    [CQ] canon iR 8500 starteing light copy
    for senior tech, i have problem with ir8500 that A4 copy starting light i replace transfer assembly, repair the problem any help me
  • teckat
    • 16083
    post the image issue-
    is the light image also shown on Network Prints
    • charm5496
      • 2387
      Does it happen on prints or internal test pages as well as copies?
      If so I would look at the pre-exposure lamps or primary carona assembly.
      • nizam
        • Mar 2011
        • 40
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5007
          I bet on transfer issue.How many million copies do you have on this masterpiece?
          • nizam
            • Mar 2011
            • 40
            1,56700 copies & 26,9466 copies i will change transfer
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              I agree with zoraldinho,, it looks like lead edge light copy caused by a transfer/separation corona. I rewire them till they get to a million, then replace them...
              • nizam
                • Mar 2011
                • 40
                I agree with zoraldints & mrfixit51. i replce the transfer/sepration corona assembly the thousend copies the problem repet, change the primeary & pre-priemary no change
                • nizam
                  • Mar 2011
                  • 40
                  i am replace transfer/separation corona the problem not ok. the lead edge light copy A4R & LGL is ok & A4 & A3 the lead edge copy light
                  • teckat
                    • 16083
                    Replace the Potential Sensor and Potential Sensor PCB
                    COPIER>OPTION>BODY>DEV SLOW set it to
                    0
                    • Matoku
                      • 173
                      Hi every tech out there.
                      I also facing this problem in a few machine of 8500. I have change the t&s front and rear block and the corona wire but still the same.
                      I also have insulate the ts block lower frame with pvc tape. It only show improvement when i reduce the transfer charge velue to 200.
                      For your info I am Using oem t&s end block for front and rear. If anyone of you have any suggestion regarding this problem are really appreciated.
                      • kingpd@businessprints.net
                        • 921
                        Make sure the machine isn't on a carpet. Had problems with that before.
                        • 20YRSEXP
                          • Oct 2008
                          • 281
                          change the TS settings in service mode. we have found setting it lower helps. usually below 100, but that will depend on where you are due to climate differences.
                          Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
                          • Matoku
                            • 173
                            Hi Kingpd,
                            you mentioned " on carpet floor" how about wooden eleminated floor? is it would effect also? if so, Am I need to use extra earthing cable (wire) for grounding the machine?
                            20yrsexp> ir8500 tr-1 & TR-2 setting default is 531. And this I think Too much if I set to 200.
                            I worried it will sparking and demage the drum as well.
                            • teckat
                              • 16083
                              if your outlet is properly grounded and voltage between Neutral & Ground is =less than 0.5v u are good-
                              all printers have static electricity to deal with
