CLC-1120
  • T911
    • Jun 2007
    • 628
    CLC-1120
    i need to adjust image center its' shifted to the right about 6mm. then i'll need to adjust lead edge void it's set to about 8mm. what mode is it on this one. thanks t
  • charm5496
    • 2387
    make sure your attraction and registration clutches are in good shape and your registration roller is moving freely. At that point you have to go into service mode and do the A and B side attraction and registration adjustments.
    You should really get a manual before tackling these adjustments.
    • teckat
      • 16083
      Check your PM/ this is your Lucky Day
