IR 5055 with Error E000000-0010
  • tmanamore
    • Sep 2009
    • 74
    I have a Canon IR5055 with an error E000000-0010. What does that code reference to?
  • jacky
    • Jun 2009
    • 61
    Code
    Description
    Remedy
    E000
    The heater fails to heat.
    After correcting the fault, be sure to reset the error. (COPIER>FUNCTION>CLEAR>ERR)
    0000
    After power-on, the reading of the main thermistor does not increase to 70 deg C or higher within 20 sec.
    - Replace the main/shutter thermistor.
    - Replace the DC controller PCB.
    0010
    The power has been turned off and then on without resetting the error.
    - Reset the error. (COPIER>FUNCTION>CLEAR>ERR)
    Hope it will help you.
    • jacky
      • Jun 2009
      • 61
      1. In service mode > COPIER > DISPLAY > ANALOG, check
      the temperature displayed next to the following items:
      - FIX-U
      - FIX-UE
      - FIX-SHTR.
      With the fixing feeder assembly pulled out, make sure that the
      temperatures are as follows:
      - FIX-U: 20 deg. C
      - FIX-UE: 8 deg. C
      - FIX-SHTR: 8 deg. C
      If any of them is
      230 deg. C or higher, the main body may have
      a defective part (D-CON, cable, etc);
      To put it the other way
      around, it is unlikely that the upper fixing unit is faulty.
      Note: It’s relatively rare but a fault in the upper fixing unit causes
      the DC controller to go out of order.
      2. With the fixing feeder assembly set, check the temperature of
      the following item in service mode > COPIER > DISPLAY > ANALOG,
      [FIX-U, FIX-UE, and FIX-SHTR]
      If any of them is 230 deg. C or more (*), a short-circuit may occur with
      the corresponding thermistor / fixing feeder cable.
      * If the fixing assembly has cooled completely, the temperature will be
      same as the room temperature. If the measurement is performed
      right after the assembly is heated, the temperature will become 50
      to 200 deg C.
      3.
      If the temperatures do not change even though the fixing feeder assembly
      is pulled out and then inserted again, the following are conceivable:
      - The thermistor has an open-circuit.
      - The fixing feeder assembly cable is broken.
      - The DC controller is faulty.
          - A cable of the main body is broken.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        Usually CLEAR-DCON help for this issue but first check thermistors counter (DRBL-1)
