Canon scan to email
"Harvey Dent"
oknaru
canon 2018i scan ti email setup
postcast started working but giving error as ERROR : 550 5.7.0 static :70.105.60.179 rich .east.verizon.nt(70.105.60.179) blaklisted y zen.dnsbl....
i am trying without postcast also now ....to see if can bypass verizon...as my 3rd party email vendor zebra.com has allready relay the smtp for ip 70.105.60.179 as discussed with email vendor...if any ne has solution for above error ....in the mean while
...My scan to file is working fine for all the clients as define ....but this is clients requirement so taking it as a chalange...
thanks all for taking yr time...Comment
hi
what is this static ip 70.105.60.179. if you can't ping you can't send email.
Most important for send to e-mail
1 SMTP Mail server IP address or Name.
2 DNS IP address
3 A e-mail address (prefer valid )
4 Domain name.
5 Need to check if the mail server need user login ( if required then E-mail Address of the user should be use)
As for postcast, do a test from another computer. Use another computer and config the e-mail client (outlook or any client) to point its smtp sever to the computer loaded with post cast and send a mail to see if it is workingComment
