setup IR C3220-C1
  • pontiac
    • 420
    setup IR C3220-C1
    could someone tell me what I have to do to setup send or scan to a sepicific hard drive and folder with a IR C3220-C1 with universal send. I have installed scan gear and does find machine.
  • teckat
    • 16078
    did u install the correct Scan Gear for COLOR PRINTERS ??
    You must specify the destination (such as an e-mail address, I-fax address, or file
    server address) in order to send documents. If you store addresses in the Address
    Book, you can easily select them. Addresses are stored in Address Book Settings
    (from the Additional Functions screen).
    The ScanGear Tool cannot be started at the same time as the Network ScanGear driver.
    โ€ข Before selecting a network scanner, first you must switch it online.
    Switching the scanner online enables communications with other devices on the network, and allows the scanner to receive data from the computer.
    • DFM914
      • Jun 2010
      • 73
      I think you would want to use Universal Send SMB scanning. Press the Send tab on the display, choose file then change protocol from FTP to SMB and press the browse button to see domains or workgroups available. The method you mentioned is "pull scanning" vs "push scanning" There are instructions out there do set it up.
      • pontiac
        • 420
        Thanks for replys it was the scan gear software, wrong model.
        • teckat
          • 16078
          It Happens a lot out there with Scan Gear
          , good luck
          • asky
            you must set up a shared folder on the workstation you want to scan to then browse using smb on isend to that workstation log in with your normal user name and password and browse to shared folder to set up path.
            • teckat
              • 16078
              • Raoufselwaness
                Expert
                • Nov 2008
                • 75
                hi, teckat
                how to set up irc 3220 as printer-net(ip setting)
                • Raoufselwaness
                  Expert
                  • Nov 2008
                  • 75
                  irc3220
                  i have set up driver ps3 and driver pcl5c and it prints but at printer side prints are NG
