canon ir 6000 have white dots how to prevent it
  • zamamd
    • Jul 2008
    • 7
    hai every one, i have 2 ir6000 machine,the problem is the white dots apeear at my drum surface.i try change carona wire but the problem still happen. now my drum have to many white dots. my machine printing is very bad now.i want to know why sparking drum happen and how to solve it or prevent it. please help me..........malaysia
  • mr.daus
    • Apr 2011
    • 98
    you can try replace potosencitive drum
    firdaus +(62)8195002007 firdaustrish@ymail.com
    • mr.daus
      • Apr 2011
      • 98
      you can try replace the potosencitive drum
      to prevent it you should replace the coronas with continues time
        • 22930
        I agree with the two previous posters. Arcing between the primary charge unit and the drum will cause the void dots in the drum surface. It makes sense to replace the primary charge unit once in a while, to prevent damaging a $2K drum. =^..^=
        • CT Copier Repair
          • Mar 2010
          • 304
          Drums already pitted
          replace it and the coronna units
          time for maintenance a canon tech would have done this already
          LOL
          • mrfixit51
            Lead Service Technician
            • Oct 2008
            • 1975
            LOL
            If I might make an observation, a GOOD tech would have done this already...
            • gensys
              • Jan 2011
              • 324
              LOL
              See Portable Manual / Chapter 1/ Cleaning 1.4-...................
              mrfixit51 > the rights
              The Road will be Mastered by >>> the Going...
              • D_L_P
                Self Employed
                • Oct 2009
                • 1196
                I was having this discussion with another tech just the other day. Sometimes no matter how well you maintain it, those drums just get pitted. Just bite the bullet and put in a new drum + corona assy's.
                If you have an account that doesn't care about the white dots in solid areas, you can leave the wires in for 1 mil (I never tried but he said it can be done). But if you really want to minimize the pitting, just do the routine maintenance. Don't let the wires go more than 250k, replace the blue cleaner pads with the wires, and replace the entire corona assembly every 1 million copies. And don't forget the ozone filter. Anyone who worked on the NP6650 will knows heat + coronas = pepper marks. Remember shimming the primary fan duct?
                  • 22930
                  Originally posted by D_L_P
                  ... Remember shimming the primary fan duct?
                  Do I ever. And it worked too.
                  Some of those ducts got so warped though that it took two or three shim locations to keep the mouth of it open. Thanks for the memories. =^..^=
