ir 6570 displyed code E 0004-0103
  • mr.daus
    • Apr 2011
    • 98
    i have machine ir 6570 he is displyed code e 0004-0103
    any body can help for this code ????
    firdaus +(62)8195002007 firdaustrish@ymail.com
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    The IH current is faulty. (no current)
    - Check the connector for any fault in connection.
    - Replace the fixing heater power supply.
    - Replace the DC controller PCB.
    • mr.daus
      • Apr 2011
      • 98
      i'm do this solution but not good
      are the power suplay fixing heater can be repaired??
      • zoraldinho
        • Mar 2008
        • 5015
        Try to clear DC controller.Don't forget to Reset error!
        Power supply also can be repaired but depend what's wrong with supply.
        • waffu22
          • Jun 2009
          • 95
          Look at your fixing if heater lamp on. Check connector in fixing assembly
          • mrfixit51
            Lead Service Technician
            • Oct 2008
            • 1975
            As zoraldinho stated mid-sentence, make sure to try the reset procedure in service mode first, to see if you need to work further on this problem.
            copier>function>clear>err
            • vj200729
              print mate
              • 81
              better check supply voltage .is it 128 v at input of machine
