Image Press C1 Registration
  • ricardobres
    • 147
    There are some adjust to align both sides on the two side print?
  • teckat
    • 16083
    best to do it from inside the Application on your PC or Mac-
    C1-Duplex operations>>>
    At double-sided printing, in order to correct the displacement of the image position of the second side in the main scanning direction, side registration detection is performed and thus the laser write start position is corrected.
    Detection of the home position of the side registration sensor (PS25) is performed at power-on, open/close of the front cover, open/close of the right upper cover, open/close of the right lower cover, recovery from the power-saving function, and end of print, and then brought to the 13x19 paper detection position.
    When the paper fed to the duplexing left feeding assembly reaches the duplexing left sensor (PS19), side registration motor (M21) is turned ON and then the side registration sensor (PS25) detects the edge of paper.
    Detection start position is set by recognizing the cassette size and the slide guide width of the manual feed tray at the start of copying so that the paper edge is positioned to feed ideally (In case of A4 paper, 165 mm from the center of the unit).
    or.....
    COPIER>ADJUST>FEED-ADJADJ-REFE
    Adjust the horizontal registration for double sided copy.
    Adjustment method
    When you increase the value, the second side image moves to the rear side. (When you
    increase the value by 1, the image moves by 0.1mm.)
    Adjustment range: -100 to 100
    [Factory setting value / Value after RAM clear: 0]
    BLK-SML2
    Adjust the right and left margins on the second side of a small-size sheet.
    When you increase the value, the left and right margins on the second side become longer.
    (When you increase the value by 1, the margins increase by 0.1mm.)
    Adjustment range: -50 to 50 (Unit: 0.1mm)
    [Factory setting value / Value after RAM clear: -15]
    • ricardobres
      • 147
      Thanks, I'll try it tomorrow, now here is 22:11hr
      • teckat
        • 16083
        More info for DADF R1
        In case of pickup in simplex mode and in duplexing mode (1st side)
        The service mode item to execute the leading edge registration adjustment in case of pickup in
        simple mode and in duplexing mode (1st side) is as follow:
        FEEDER > ADJUST > DOCST
        1) Set either one A4 paper or LTR paper [1] on the document tray.
        2) Display the Service Mode items and change the setting values.
        The changes in these setting values make the difference in the leading edge registration values
        between the single feeding and the duplexing feeding (1st side).
        - Setting Range: -30 to 30
        - 1 Unit: 0.5 mm
        A higher setting will decrease the margin, while a lower setting will increase it.
        3) Press [OK].
        -> The original is picked up, and stops on the copyboard glass.
        4) Open the ADF and check the position of the original.
        5) Press [OK].
        -> The original is delivered on the delivery tray.
        6) Escape from the Service Mode.
        When picking from the manual feeder tray (2nd side) and also in duplexing mode (2nd side)
        In the case of pickup from the manual feeder tray (2nd side) and also in the duplexing mode (2nd side)
        The service mode item to adjust the lead edge registration is as follows:
        FEEDER > ADJUST > DOCST-M
        1) Set 1 sheet of A4 or LTR paper either on the manual feeder tray or scanning tray.
        When picking up from the manual feeder tray, set the paper against the rear side.
        The following indicates the example of steps in the case of pickup from the manual feeder tray.
        2) The following operation is the same as 'A. in the case of pickup in a simple mode'.
        Reference:
        See 'A. In case of pickup in simple mode and in duplexing mode (1st side)'.
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5015
          -Print job in mailbox>select job>print>change print settings>options>shift>settings for front
          and back side by the numeric keys
          • charm5496
            • 2387
            There is a tray alignment feature on the Fiery as well where you can align the front and back side of each tray individually. After storing the settings you will have to enable it in the print driver.
            • teckat
              • 16083
              just a reminder>>
              if u are trying to align crop marks on two-sided prints/ be aware, each App u use has it's faults, especially when clients send u these docs and don't know how to prepare them
              • mark921
                • Dec 2010
                • 110
                Also, in Command Workstation, under finishing you have the ability to shift the front and back of a document up, down, left or right independently. Works great, but does take a little longer to set a print job up.
                • teckat
                  • 16083
                  that move is trial and error/ and a time issue
                  • mark921
                    • Dec 2010
                    • 110
                    very true, but if close to hairline registration is the goal, it serves the purpose.
                    • vigour
                      • Aug 2010
                      • 1038
                      That is great Charm. I didn't know about enabling it in the driver
                      • ricardobres
                        • 147
                        Guys, I did the adjust, andresolved, but some printer later, it's out again. I think the problem is in the imagepass. This machine works with the imagepass H1? When I do copiers, the alignment on both sides, is ok, but on the printer, no. So, I think the problem is in the imagepass.
                        • teckat
                          • 16083
                          use the application u are printing from- for the alignment
