TONER IR5000
  • bakaoni666
    • Mar 2010
    • 56
    [Misc] TONER IR5000
    I've a problem with iR5000. It run out of toner so quick. How can i fix it?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    We can not measure toner life with time.
    -How many copies machine make with toner bottle?
    -What do you printing? (%%%%%%)
    -Is it print too dark?
    -Do you have hooper issue(toner leaking)?
    • bakaoni666
      • Mar 2010
      • 56
      normal use
      it's about 7500 sheets for 1kg. usually 20000sheets/kg ( sometimes more ).
      only text copy.
      2 years ago i found this trouble on NP 6050.
      i forgot to plug the erase lamp.
      1kg for 5000 sheets.
      • charm5496
        • 2387
        well what work has been done to the machine lately? You may want to revisit that work and make sure it was done correctly
        Are you using genuine Canon toner? Off brand toner is not reliable and could be causing an issue.
        The 30,000 sheet estimate for this machine is based on 6% coverage and if you have a lot of bold text or the page is full of text then your coverage will be much higher than the 6%.
        If you are not having any CQ issues you may want to have a tech come out to make sure that the machine is running within spec. Also are these copies or prints? Even though you are outputting just text when copying or printing in text mode your image will come out much darker than setting it on publication on the print side or text/photo on the copy side.
        • charm5496
          • 2387
          6%_sample[1].pdf
          Here is a sample of 6% coverage:
          • gensys
            • Jan 2011
            • 323
            If the iR in a good condition, prints of 1 kg of an order from 28000 to 32000-35000 copy at (5%)
            Cleaning (cheking) Prim. Toner Blocking Sheet
            Cleaning (cheking) Dev. Toner Blocking Sheet
            Cleaning (cheking) Cleaner Scraper
            Remove the Push-on roll chek- replace
            Cleaning (cheking) Drum, mirror, Prim. corrona..................
            The Road will be Mastered by >>> the Going...
            • D_L_P
              Self Employed
              • Oct 2009
              • 1196
              Just another suggestion.
              Copier-> Option-> Body-> COTDPC-D -> Set to 1
              • bakaoni666
                • Mar 2010
                • 56
                for factory use... there is no other explanation about that option.
                will you explain more clearly Mr. D_L_P
                Thanks a lot.
                • bakaoni666
                  • Mar 2010
                  • 56
                  Over a month the machine work normally. a week ago i cleaned the pretrans. in 2 days it was full again. i cleaned it again. 2 days later the same things happened. I try to checked the cleaning unit in drum unit. it full with mixed toner (good toner-black & waste toner-grey).
                  Sorry for may bad english...
                  • charm5496
                    • 2387
                    and your image quality is fine? Just want to make sure of that and that no other service mode settings were adjsuted beween when the machine was running "normal" and now.
                    • D_L_P
                      Self Employed
                      • Oct 2009
                      • 1196
                      My former employer was quite the bean counter. I'm sure many techs remember "TSON". Anyway, here is a ss of the manual explaining the toner save.
                      • gensys
                        • Jan 2011
                        • 323
                        [ATTACH=CONFIG]9346[/ATTACH]
                        It is pleasant to see the professional answer.
                        • bakaoni666
                          • Mar 2010
                          • 56
                          WOW many thanks to You..
                          It much better now.
