adv fin a1
  • roho
    • Mar 2009
    • 844
    [Dead] adv fin a1
    Good day! I have an ir adv 5035 inner finisher a1-it was installed 1 day ago-latest firmware.
    Now it throws error codes and jam codes for the finisher. The gripper assembly seems to seize up upon initialization. I have had to replace the gripper rail before, this one has the modified rail. Upon dissambly, the gripper seems to move freely. I was wondering if anybody has seen this problem before. Between this problem and the gripper rails, I swear I could take this finisher apart in my sleep.
    Thanks in advance!
  • CanonSco
    Man About Town
    • Jul 2010
    • 368
    What error codes / jam codes?
    Yes, I am a nerd.
    Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
    • roho
      • Mar 2009
      • 844
      e 572 003-the jam codes are error induced for the finisher gripper init.
      • CanonSco
        Man About Town
        • Jul 2010
        • 368
        If you remove the gripper and manually wind the gears to their home position? Does it do the same?
        You say the gripper "seizes" up , is it the gripper seizing, or is it hitting the plastics due to it either being o.o.p / open?
        This is a brand new machine, yes? Do they come with the modified gripper as standard there? ( modified gripper arm holder ) as these , at least in the EU , had to have the rear sensor arm cut when installed or they travel too far back.
        Out of my 150+ IRAC50XX machines, I have had to replace 3 grippers for being faulty. These either did not "open" correctly , hence hitting the plastics exiting the machine. Or in the case of 1 caused 1101 jams even though it was the newer type.
        Yes, I am a nerd.
        • roho
          • Mar 2009
          • 844
          The gripper is the new style-manually worked fine-turned out the delivery out put rollers on top were slightly dislodged, causing the gripper to bind and grind from above. Looked like a gripper issue, but was probably due to the movement of the machine.
          Thanks for your help!
          • CanonSco
            Man About Town
            • Jul 2010
            • 368
            Ahhh. Crashed finisher.
            Get used to it on the A1's
            Yes, I am a nerd.
