Help needed np 2020 CANON copier
  • vixentd
    The code is EOOO which I think means fuser. Apparently you can try to reset by pressing switch 301.
    I have taken off the back cover but can not find this switch?
    Any guidance appreciated.
    I did a search and nothing came up. Perhaps to old.
    • 23010
    Not in the back
    On the left hand side of the copier there is a small 2" x 3" door lower rear with one screw. Inside is the side view of a PCB where the switch is, and various other adjustments.
