Canon IR2030 :Sharp lines across copies.
  • DAG COPIERS & COMPUTERS
    • Oct 2010
    • 860
    Hi, to u all members out there. I have this m/c ir2030 still new, complete with DADF & INNER FINISHER, has done about 4000 copies on the counter. Sometimes it produces copies with a pencil thin sharp line running across the entire length, on both portrait & landscape .The fault is common to both stream reading & copy board functions. I thoroughly cleaned both glasses above, as well as reader unit; disassembled & cleaned drum assembly , just in case, but didn't touch the laser unit. As I stated above, this symptom is intermittent, on certain copies, then not on others.
    Any opinion, based on experience even on other or similar m/cs is highly appreciated. Remember the machine is still new.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    post image please.
    • jiongpao
      • May 2009
      • 413
      i got a same case on ir3300 but after changing a new drum unit everything fine. Although its new sometimes the blade cant clean swallow thin line on it.
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        Is this machine the Color Advanced imageRUNNER 2030??
          • Oct 2010
          • 860
          No Sir, the machine is a black n white canon ir 2030, not color.
          • mrfixit51
            • Oct 2008
            • 1975
            Now I understand the beasty you are referring to,,, the iR2022 is the one I see in my area, same family. The drum is the most likely candidate, the only other rational candidate might be the CIS unit, (the scanner assembly), but that is most unlikely...
            • teckat
              • 16083
              if for a Digital Line that comes and goes
              Remove and Re-Seat Ribbon Cable to the CIS unit.
              do a CIS adjustment in service mode
              check slit glass
              line is in paper feed direction-in same location ??
                • Oct 2010
                • 860
                Thanks a lot to u all gentlemen for your opinions, I will get to the machine again and give it another trial based on your help and keep u updated. Thanks teckat for the ATTACHMENT u had posted as a backup. Unfortunately the file could not open up, it says invalid.
                • teckat
                  • 16083
                  forget about damaged file-
                  it is like the picture posted below it with red arrow pointing to digital line that comes and goes
